HOUR METER MOUNT
HOUR METER MOUNT
Where is the best place to mount an hour meter on a H series KDX using a 6mm bolt?
Re: HOUR METER MOUNT
Hmm, never thought about it and have no clue, honestly. I always have used double sided foam tape.
might try the bolt that holds the CDI unit on, though I've always also used double sided tape and a zip tie
Double side tape for me, left side of the tank deep behind the shroud.
I have a temporary spot on my flex bars held on by zip ties until I find a more permanent spot
- Trackdog
I mounted mine with two-side tape(and I use a zip tie for peace of mind) to the Devol radiator guard
- hour meter.jpg (34.41 KiB) Viewed 471 times
2004 KX 125
1986 CR 125
1994 DR350
1998 VFR
2004 DUCATI S4R
2004 KX 125
1986 CR 125
1994 DR350
1998 VFR
2004 DUCATI S4R
