Can anybody please tell me what the ohm readings of the stator coils of a 1991 KDX250D have to be when tested with a multimeter.
My bike starts OK, runs OK for the first few miles but then all the sudden it will start to bog down and dies when going down a long downhill (not very steep). It sounded like it is not getting enough spark. I've cleaned the Carb, set the float level, new spark plug (a lot of them). The carb also does not overflow. I also tried to jet the bike a bit leaner, but that does not make a difference. There is also a lot of spooge. The bike also only just idles. The idles screw is screwed in all the way.
Now I figure it must be the stator coils (Magneto). Just want to check if it is within specs.
