New to site.
Bought pair of 94 kx250 forks, hoping they will go straight on to my 91 kdx250 as their both listed 43mm. Any info much appreciated.
Thanx in advance
94 kx250 forks
Re: 94 kx250 forks
If they are what you say they are, then they will fit the same. It is not because they are 43 mm. It is because the outer tubes are the same diameter in the upper and lower clamping areas. You will need the KX front wheel to mount to the KX forks or use a custom machined spacer / adapter.
Look at what the guy on KLX Plant ( I think that is the site name) did.
And welcome to the forums.
Re: 94 kx250 forks
Ok cool thanx for the feedback. Would i need the kx front brake also?
