LOW RPM BOGG
Posted: 08:15 pm Sep 14 2017
by garycrafton
my bike boggs down bad at take off,,no low end power once I get the rev up its great .// ?? almost dies if I don't give it enough throttle at take off ???? help !!!!
revs up just fine in neutral just not when pulling weight ??
Re: LOW RPM BOGG
Posted: 08:52 pm Sep 14 2017
by bufftester
Which bike? What year? New development or always been that way? Mods/work done? Last time you changed plug, cleaned air filter, what's it currently jetted at? Need more info
Re: LOW RPM BOGG
Posted: 06:26 pm Sep 15 2017
by garycrafton
bufftester wrote:Which bike? What year? New development or always been that way? Mods/work done? Last time you changed plug, cleaned air filter, what's it currently jetted at? Need more info
OK,,,just got it this is a kx80,,1993 I know this is a kdx forum, I have one too this is my kids bike,,,dont know much about it ,,,was locked up when I got it put a used motor in it ,,new plug and airfilter
Re: LOW RPM BOGG
Posted: 06:33 pm Sep 15 2017
Moved to other bikes forum
Have you cleaned the carb?
Re: LOW RPM BOGG
Posted: 08:25 pm Sep 15 2017
by garycrafton
Jason wrote:Moved to other bikes forum
yes ,,even tried a new carb same thing
Re: LOW RPM BOGG
Posted: 08:36 pm Sep 15 2017
by garycrafton
yes,,,no change
Re: LOW RPM BOGG
Posted: 12:36 am Sep 16 2017
by Yeahthebikes94
Air leak around the carb perhaps, check the seal around the airbox boot and reed block boot.
Also double check the idle jet isn't blocked, and set the air screw to 1.5 turns out.
Get your idle set right next and hope it works
Re: LOW RPM BOGG
Posted: 12:38 am Sep 16 2017
by Yeahthebikes94
Could also be a timing issue, try moving the pick up around to advance/retard the timing and see if there is any improvement.
Re: LOW RPM BOGG
Posted: 08:49 pm Sep 16 2017
by garycrafton
Yeahthebikes94 wrote:Air leak around the carb perhaps, check the seal around the airbox boot and reed block boot.
thanks ill try that ,,
Re: LOW RPM BOGG
Posted: 07:31 pm Oct 10 2017
by garycrafton
ok did all that ,,no change
Re: LOW RPM BOGG
Posted: 09:17 pm Oct 10 2017
by Yeahthebikes94
Take reeds out and look for damage, also flip them if they are worn.
Is possibly still a timing issue.
What ratio premix are you running??
Re: LOW RPM BOGG
Posted: 07:40 pm Oct 19 2017
by garycrafton
Yeahthebikes94 wrote:Take reeds out and look for damage, also flip them if they are worn.
using 80 to 1 amsoil,,gonna install new reeds tomorrow,,,thanks
Re: LOW RPM BOGG
Posted: 04:04 pm Oct 21 2017
by Yeahthebikes94
80:1 ratio?! I run all my 2 strokes at 40:1. Try the new reeds and fuel ratio change
Re: LOW RPM BOGG
Posted: 03:22 pm Oct 23 2017
by Julien D
I will second that, 80:1?!?!
