Page 2 of 2
Re: Will an '87 piston work in a '83 200 ?
Posted: 04:00 pm Dec 21 2017
by mjlovejoy4
So I am a complete idiot and couldn't follow the technical aspects of this post if I tried. At the end if I read the last post right you can make my 200 a 240 and that would eliminate my not finding a piston kit problem. Sorry such a newbie
Sent from my Moto Z (2) using Tapatalk
Posted: 08:09 pm Dec 21 2017
by KDX Geoff
My 200 has had the barrel sleeved out to 72.5mm from the standard 66mm.
I found a piston (out of a later model 240cc conversion) where the main measurements were right other than the skirt length so l took off the extra 6 odd mm and matched the profile of the piston that came out. It wasn't pull the old piston out and put the new one in.
If your bike has a standard 66mm bore, buy this Wossner piston and check the ring pin location in your barrel and fit it or get some help if you need too
Much easier than converting to 240cc.
Posted: 10:01 am Dec 23 2017
by mjlovejoy4
KDX Geoff wrote:My 200 has had the barrel sleeved out to 72.5mm from the standard 66mm.
I guess when the time comes I'll have to find some help here in South East Oklahoma I've never worked on a dirt bike but I really like this bike and want to keep it around a good long time. If anyone is around this area I would be happy to drive a bit to get this bike in top shape. Everyone I've talked to around here just says I'm out of luck
Posted: 03:19 pm Feb 09 2021
by Pukwudgie
Can anyone confirm that they've fit and run a Wossner '86-'06 in a '83-'85 jug? I'm researching the topic and there are conflicting takes on whether you need to modify the piston skirts and, or if there is interference between rings and ports etc. Its also been stated there is added head clearance which would lead to lower compression would it not? If anyone could share experience fitting one of these would be great. Thanks
Posted: 03:22 pm Feb 09 2021
Welcome to kdxrider.net. Thanks for joining us and participating.
