SEEKING SAND RIDING TIPS
Have a question about technique?
Duke
Post by Duke » 10:47 am Apr 19 2009
At Hungry Valley ORV park, there is a crude MX track that serves as a good way to practice turns. Most of the turns have deep sand. In negotiating these turns I find the bike wallowing about like a shopping cart. From a mecahnical stand point I can stiffen the compression on the forks (.38 KG springs). From riding tactic standpoint, I assume being aggressive on the throttle and moving my weight back a bit will also help. Any other tips that folks could add?
island220
Post by island220 » 09:30 pm Apr 19 2009
compression will help,make sure you have proper springs for your wieght in front and back, then set sag,this helps but the kdx front end is the weak point switching to kx front end really helps.
Duke
Post by Duke » 11:16 pm Apr 19 2009
Yea, I am aware of the fork swap, but I am not keen on spending the time and money for such a conversion. Instead, I am seeking riding tactics that will aid me in this endeavor. I have seen riders on XR250's negotiate such terrain in a faster and more refined manner then me. And KDX forks are the equal to any OEM XR250 fork
Post by Indawoods » 11:23 pm Apr 19 2009
When I am in a situation such as yours... I pull off the track and watch exactly what everyone else is doing... listen to the motor... look at their form.. watch the back tire... watch their hands.
I am not familar with sandy conditions personally, I am just trying to help you help yourself. :wink:
island220
Post by island220 » 12:51 am Apr 20 2009
sorry about the direction I went Iwould recomend stay back on seat more and higher gear and feather clutch, I know what you mean about wallowing in corners,on rougher corners try standing and keep the front end as light as you can otherwise the front tire starts acting like a plow.
MXOldtimer
Post by MXOldtimer » 08:38 am Apr 20 2009
Drop your fork tubes in the T-clamps. You want to raise the front and carry your weight more in the rear and keep the front end light.
Forget what you've been told about riding on the gas cap you don't want to dive into turns sticking the front end, the sand will catch your front tire. Try to be smooth and arc tuns, stay on the gas keeping that front end light, weight a little to the rear. If you chop or shut off the gas it's cause your front end to dive so stay on the gas and steer with the ass end. The bike will move and drift under you, let it go and don't fight it.
Duke
Post by Duke » 11:31 pm Apr 20 2009
Thanks every one for the input. I will put it to use at next ride session and report of the progress
Duke
Post by Duke » 09:35 am May 18 2009
Duke wrote:Thanks every one for the input. I will put it to use at next ride session and report of the progress
Well, I ventured to Hungry Valley and proceeded to put to practice those offerings listed above. The two single best tactics was for me to sit back farther and to completely relax my upper body; slumped shoulders, arched back, light grip and more squeezing the bike with the legs. I elected to focus on smoothness and not speed. But the latter quickly followed in due time. Thanks all for the advice.
TWMOODY
Post by TWMOODY » 02:33 pm Jun 07 2009
Old thread but I will add my 2 cents
All I ride in Michigan is sand and sometimes it really sucks but
a bad day riding is better than a good day at work, kinda like fishing.
Go into the corner on the higher side somewhat on the throttle !
Half way through give it more and steer with your weight.
If you start to dive or chop give it more throttle to regain control.
Always think the more throttle the more control, sometimes
hard to do if your tired.
Try and go slow through some deep dry sand then try it again
going much faster and you will feel a huge difference in control.
Kick the forks down in the clamps and stay off the tank!!!
I ride so much sand it's sometimes hard to adjust to dirt and hardpack..
tjg53
Re: SEEKING SAND RIDING TIPS
Post by tjg53 » 04:53 pm Oct 07 2013
we'll I'm in mi. too , and we have lots of sand that for sure. What is bad about the kdx is no rebound. Becase that is what it needs , is the rebound to be slowed down so it will steer better. The stock fork aren't bad forks , a revalve is needed for this. Gold valves could help with that.
TWMOODY
Post by TWMOODY » 06:28 pm Oct 10 2013
Where in mi ?
diymirage
Post by diymirage » 10:09 pm Oct 10 2013
lower rear tire pressure and get on the gas
MI trails are terrible, especially halfway through the season once everyone has been through there and tore it up
