Should I RB before they’re gone or lectron
Posted: 08:26 pm Jun 27 2019
by spencerdiesel
Hey all, I’m excited to be joining this forum! I’ve been researching KDX literature for a few months after deciding it’s the bike for me. I know I’m years late to the KDX game but I want to learn the best I can before KDX support fades.
Does anyone have reccommendations as to a new RB modded carb vs a lectron? I’ve read a few threads on here about the lectrons and it’s seems they have finally dialed in the fitment issues.
I love the notion of being able to meter and fine tune a set A/F ratio with an external adjustment, especially if the lectron is as crisp/ responsive as the RB.
However, having no real world KDX experience (or lectron or RB experience), I would love input of y’alls opinions and experiences with both carbs.
The reason I’ve made this post before even acquiring the KDX is I’m afraid the RB option may be gone soon, and if I decide that’s the route I want to go I’d like to order one before that happens.
I do have good knowledge and aptitude with jetting, as I’ve perfectly (as close as can be anyway) jetted my crf100 and rm125 via plug chops and cutting the plugs. Though once again, the external adjustments (I can tune via plug chops & make corresponding reference marks) sound so appealing.
Please educate me, and thank y’all!
Re: Should I RB before they’re gone or lectron
Posted: 03:36 am Jun 28 2019
Welcome to kdxrider.net. Good luck on the KDX hunt. Good start to already know about plug chops.
Reminder: Full Editor, Attachments, Add Files, Place inline to add pics on here
Posted: 05:57 pm Jun 28 2019
by spencerdiesel
Thank you!
I’m also semi settled on a PC platinum 2 if that has any influence.
Posted: 07:52 pm Jun 28 2019
by SS109
Personally, I like an RB carb better than a Lectron but I have no direct experience with both on a KDX.
My RB carbed 220 has instant throttle response and, even though some will say they are more jetting sensitive, all I've ever done is raise or lower needle a clip depending on weather and elevation. Yeah, it's dialed in perfectly that way but it's damn close. I've never had spooge running out my silencer or fouled a plug. I ride in temps from about freezing up to 105 degrees and elevation of 1200 to 6500ft.
My Lectron experience is on my GasGas EC250. It has performed well and has been a set it and forget it kind of deal. However, I don't feel the throttle response is as crisp and responsive as an RB carb. That said, it could be I don't have it dialed in good enough yet and/or the Rekluse auto clutch is just making it feel that way. I think the Lectron would probably be best if you ride some serious elevation changes or just hate messing with jetting.
So, take what I say with a grain of salt. I would probably put the experience of those with Lectrons on KDX's over my experience.
Posted: 06:19 am Jun 29 2019
Unfortunately, what you need is that magic someone who bought a new RB carb AND a Lectron AND swapped them back and forth AFTER perfecting jetting on both.
Otherwise...
"well... his RB carb was just modded, not bought new"
"well... did he have it jetted perfectly"
"I HAVE ONE AND I LOVE IT"
etc.
Posted: 08:04 pm Jun 29 2019
by spencerdiesel
These are all great points. The main reason Im ever so slightly leaning towards the Lectron is I like to jet as close to peak power as possible for my "home riding" elevation of 3000 feet. If we ride in GA or SC I will be 1-2k lower elevation and be at the most dangerous point; the lean side of peak power.
This is no big deal as I know how to jet and can do so as long as I make time for it. Often our trips as above are semi spontaneous and short, kind of a "hey lets go to SC in the morning".
I can play safe by staying jetted for the lower elevation and being a little rich back at home, but I do like being jetted ideally as opposed to a rich compromise.
I guess having the luxery of an on-the-fly adjustable A/F ratio has got me a little excited. Also, doesnt the lectron allow one to have nearly linear (no steps/ transitions in circuits) response and eliminate intermittent 4 stroking/ rich blubbering?
Posted: 10:35 am Jul 04 2019
by javjacob
Get the RB carb.
Posted: 10:05 am Sep 19 2019
by spencerdiesel
Picked up a very clean and seemingly low hour ‘95 KDX200! The reason I believe low hour is it has a kenda Millville rear tire, didn’t they stop making the original Millville like 2010?
Anyway I got a great deal because the PO couldn’t figure out why it ran ridiculously rich past 1/2 throttle, even with the needle clip in the top, said it had the stock 48/ 160 jets. He had his Kawi shop put new crank seals in it, but that wasn’t it.
Well lo and behold I rode the bike and it wouldn’t pull over 6k rpm WOT, smoked and 4 stroked like no other. Pulled the MJ out and it was a 180!!! Put a 40/ 155 in there and the major part of the issue was solved, albeit still rich on pilot and main (stock pipe).
Set float height to 17mm, removed the jet block and replaced the jet block o ring.
I took about 2 hours to decipher the keihin needle chart on the JetsRus website and ordered CEQ & DEQ needles based on my observations of the stock needle. I have the CEQ in right now and there is zero 4 stroking from 1/8 throttle on up, and no leak spots via plug chopping. I’ve also learned real quick how rich the stock #5 slide seems to be, as I’m down to a 35 pj and it still 4 strokes at 1/16 throttle.
Ordered a PC platinum 2 pipe, and emailing Ron for a new RB carb. Do all RB carbs come with the thumb adjustable air screw? Thanks y’all!
Posted: 04:15 pm Sep 19 2019
Congratulations on getting it going!
Posted: 10:54 am Sep 22 2019
by Vossman
Mine came with additional jets but no adjustable screw. He does not make them anymore. JD makes a good brass one though. He will jet it for your location though so it should be close.
Posted: 10:56 am Sep 23 2019
by stnd
Vossman wrote: ↑10:54 am Sep 22 2019
Hi. What is JD? I am also looking for a mixture screw. Can the idle screw also be replaced on these PWK carbs to something i can adjust with my apparently weak fingers:? =)
Thank you.
Posted: 02:06 pm Sep 23 2019
Posted: 01:48 pm Jan 10 2020
by kvkdx
2001 KDX 220r, I had stock carb and bike ran good but not as clean as I wanted, I was going to send carb to RB or Fredette and then I got advice from my riding gurus and all said go Lectron, I just installed LECTRON 34mm carb on my KDX monday, HOLY COW my bike feels like a 250 legit, it rips and is way more torque, I can be in 3rd gear stoped and roll the throttle and my bike RIPS, seriously, the idle is now perfect soudns like my KTM 300 as it idles, bike warms up faster, starts super easy, I couldnt be happier w electron, oh and by the way, I just installed out of box and thats it, it has run amazing, no tweaking, seriously get a LECTRON
Posted: 04:16 pm Jan 15 2020
by RedstoneDC
kvkdx wrote: ↑01:48 pm Jan 10 2020
2001 KDX 220r, oh and by the way, I just installed out of box and thats it, it has run amazing, no tweaking, seriously get a LECTRON
Sounds like they got the fit dialed in then? Bolted up easily, etc nothing funky? Thought I'd read something about weird fit on the 220. thanks!
Posted: 11:08 am Jan 23 2020
by kvkdx
RedstoneDC wrote: ↑04:16 pm Jan 15 2020
Yes, my mechanic buddy stood behind me and observed so I didnt screw up (he broke his wrist snowboarding and I am NOT mechanically inclined) We took it out of package and it was super tight, then we realized that I had a REED spacer on the bike, so we had to take that off and then with stock reed setup (not a spacer) the Lectron fit like a dream, easy peasy, I ordered lectron, new throttle tube and the longer throttle cable (it came with the lectron order) and Yes Lectron has made it fit very well. No issues, I fired bike up and with in 5 minutes of install was ripping down my street Ive watched VIDS on Lectrons for months and was very curious to see the actual diff on the bike, would it be noticeable
- 20200119_115957.jpg (1.03 MiB) Viewed 13928 times
?? Well I can tell you it greatly increase torque, especially cool is now in any gear, 4th gear dead stop I can roll throttle and lift front tire, bike NEVER did that w stock carb. And living in COlorado I can go anywhere and ride w no JETT worry
