Which Kawasaki forks were 56mm outside diameter?
Posted: 07:50 pm Nov 04 2023
by spencerdiesel
Hey all, I bought a used upper fork tube clamp that was labeled as 95-06 KDX. My bike is a ‘95 H. The new upper triple has a 56mm ID. Which Kawi’s had a 56mm upper fork tube? This will determine if I do a fork swap to match the 56mm clamp or cut losses with the “new” upper clamp and get a stock one.
My original upper clamp is no good due to my stupidity with a press. Thanks y’all.
Re: Which Kawasaki forks were 56mm outside diameter?
Posted: 10:50 am Nov 09 2023
by Chuck78
Good luck on finding an answer, inverted fork tube diameters are not well documented in any particular place.
If it was a KDX, it was a '91-'94 KDX 250 or '93-'94 KDX 200.
It's also likely that it might have been a pair of KX forks swapped onto a KDX, and the parts dismantler had no idea they were not the original forks and labeled them as the originals. Also could have been a pair of KLX forks, which are a direct bolt-on swap to a KDX.
I can measure my KLX forks as well as my '97-'04 KX500 (96-97 KX 125/250) forks possibly tonight or Monday if you need an answer. Post a picture of the clamps please, and also post a picture of any casting marks or numbers on the underside.
Posted: 10:55 am Nov 09 2023
by Chuck78
Whatever they were from, they were from inverted forks. I would suggest looking at the eBay seller's auctions for KDX forks and see what forks you can find photos of, including completed listings and sold items.
Posted: 10:17 am Nov 11 2023
by spencerdiesel
Thanks Chuck 78 for the info! Yea I was thinking it might be a long shot (I mean who measures the OD of their fork tubes?), was just hoping to narrow it down (which you definitely helped me with!) so I didn’t waste my new OEM bearing.
I’ll dig a little more and see what I can come up with. Would you be able to check your forks if you Chet a chance? Thanks!
