Not sure if this has been covered as my search didnt work out so well.
I have 01 kx forks on my 05 kdx220 that I detailed in another post. I would prefer not to spend $120 on fork springs. Does anyone have a list of springs that interchange?
Here are some I think do interchange
96 - 01 Cr500 98-01 Cr125; 51401-kz4-j01(.39kg), 51401-mac-781(.41kg), 51403-mac-741(.43kg)
99-01 kx125/250; 44026-1691(.44kg), 1692(.45kg), 1690/1709(.43kg), 1599(.40kg), 1707(.41kg), 1712(.42kg)
Racetech frsp 4147 series or srsp 6228
Factory connection???
Eibach???
Patriot???
If you have any more, I can add. I know at least 2 years for rm250 are same but need to find it again.
Yes I am wasting allot of time vs money, but time is free.
Thx
01 kx fork spring interchange
- Country: Usa
Re: 01 kx fork spring interchange
SRSP 6228 is a shock spring.
Look on eBay for 4147 springs.
I assume Eibach used to make some years ago. I don't think they make that model now.
I have never heard of Patriot brand springs.
If you don't mind me asking, what is your weight in full riding gear, water backpack, tools, spare parts, extra fuel, etc.?
- Country: Usa
Yes, 6228 is a shock spring. I will go back and get the alternate eibach springs from racetech, but I believe eibach own literature is different numbering like 915.025.001 as just an example.
Im about 235 loaded. See I see allot of used .44 and .46kg springs out there, but not for kx250 99-01. I see them for yz’s, cr’s, and rm’s which all had 46mm at one time. Some, like the cr500 I believe are the same 41.2 od x 470mm long that i need. Others are same diameter but 461mm long (some rm’s) and some are 480+.
So while buying new may be what I do in the end, I just thought a thread like this could help future people find cheaper used sets. Its sort of a mental exercise at this point! Lol
There are several .43kg cr500 springs out there for instance, cheap. Not .44 or .46.
Thx
Thx
.44 / .45 / .46 and 5.4 then
YZ springs in that time frame were about 10 mm shorter. I can't remember the exact length of OEM, but RT was 4146, not 4147.
ALONG time ago, they did sell odd rates.
Some springs do indeed fit multiple bikes.
- rungrandpa
- Country: U.S.A.
DRZ 350 and 400 springs are the same size. .38 and .40 I think.
