Unfortunately, I managed to let the shims fall off the valve when I disassembled my rear shock. Now I would like to verify that I have it back together in the proper order. I wanted to verify that anyway since the shock had been taken apart before and was not working well when I bought the bike. Does anyone happen to have a list of the order of the shims or a photo showing proper assembly to get back to stock? This is a 1987 KDX200.
Cheers
shock shim sham
Re: shock shim sham
Did you ever find this? as I'm in the same boat!!
Re: shock shim sham
Dan
1994 KDX 200
1994 KDX 200
Re: shock shim sham
Search around for "stock shim stack", as that is a common term used.
What year, by the way????
